SailNet Community - View Single Post - No spark from Atomic 4
post #2 of Old 05-19-2010
tempest
Have you taken the coil wire off from the distributor cap end and checked to see if you have spark going to the distributor?
Check the coil wire itself.
Also, if the rotor was cracked, I'd probably replace the Distributor cap as well.
But before you do that..check the coil
With electrical problems, I always like to do...one thing at a time..
tempest is offline
