SailNet Community - View Single Post - Do I really need to pull the mast out?
post #5 of Old 05-19-2010
mitiempo
mitiempo's Avatar
If it needs replacing, which would be doubtful after 10 years of light use, the easiest and most affordable way is to order the wire with swages at the top and a bit longer than necessary. Use mechanical fittings (Sta-Lok, Hayn or other) at the bottom and replace each yourself one at a time. The cost for the lot should be less than $800 to $1000. It is not a hard job.
Brian
mitiempo is offline
