SailNet Community - View Single Post - adhering teak to fiberglass
post #2 of Old 08-01-2001
RobHoman
I think that actually what you might want to do is take the "furring strips" of whatever wood you are going to use and mix up a two part epoxy and use that to "glue them to the wall.
I am not sure if Liquid Nails has anything that will do the trick. The other thing that I have contemplated using is a hot glue gun using #100 glue. That stuff will stick to anything! My only concern in using anything oter than proper fiberglass epoxy is that something else might react with the hull and cause problems....or just hold temporarily and then fall off.
I myself am waiting for samples of wood.. teak and some others that are tongue and groove that I am going to use to put a good finished look to the interior of several compartments of our boat. The furring strip issue is one of my concerns as well.
RobHoman is offline
