SailNet Community - View Single Post - Will epoxy glue pvc to metal
post #3 of Old 05-22-2010
scottyt
you might get the epoxy to grab, depending to exactly what the hose is made out of. there are a couple other options here
first use it as it is and use 4200 to "glue" the fitting in with minimal screw purchase
next is to close the hole smaller and "glue" a longer tail on that you can get to below for the hose clamp
the last option is to close the hole smaller and use a crimp on hose clamp. they are much smaller, do an internet search on pex tubing to get an idea of what i am talking about. somebody should make a bigger version
watch this vid at about the 1 min mark
YouTube - How to make PEX Tubing Connections.
scottyt is offline
