SailNet Community - View Single Post - Change Airmar transducer
post #1 of Old 05-22-2010 Thread Starter
spinwing's Avatar
Send a message via Skype™ to spinwing
Question Change Airmar transducer
New to me boat has old Airmar (Navico) transducers (Depth and Speed). I am replacing both as well as the wind with a Raymarine ST60+ suite. (Depth, Speed, Wind)
The problem is in getting out the old Airmar tranducers. I have removed the retractable plugs but am left with the sleeves. Sleeves and lock nuts are heavily compounded - have pretty well cleaned up one, but it is too well sealed to move.
Options appear to be to drill out the sleeves from the bottom with 2 " keyhole saw. Problem would be to keep it centered. The opening for the new transducers should be the same size.
Cutting down the sleeve with a Dremel type cutting disc, then using a 2 1/2 " socket on the lock nut. Very little room to lever socket handle.
Cutting down the sleeve with a Dremel type cutting disc, then cutting the sleeve with a hacksaw (ala removing a cutlass bearing) and then hammering out sections.
I would appreciated hearing options 4,5, 6 ......
Please sign your organ donor card.
1988 Hunter 35 Legend
spinwing is offline
