SailNet Community - View Single Post - Centerboard leak
post #1 of Old 04-30-2006 Thread Starter
mikeedmo
Take Five
Question Centerboard leak
Just had our Kadey-Krogen '86 dual centerboard cutter pulled. Seems the pivot pin on the aft centerboard had been leaking a bit. That's been fixed but water was still "weeping" from the centerboard box two weeks later. The yard fiberglass guys said it was okay to glass over the drain holes we drilled to dry out the area even though they were still "weeping" a little water. Any thoughts as to whether this might prove to be a problem further down the road or is it okay to glass up a closed space knowing there is some moisture left?
Thanks as usual for all your expert advice!
mikeedmo is offline
