SailNet Community - View Single Post - Cleaning / Washing Sails - Washing Machine ? Bleach ?
post #3 of Old 05-24-2010
KeelHaulin
STARBOARD!!
KeelHaulin's Avatar
I would be VERY careful. On the issue of mildew; the best you can do is use a mixture of bleach but don't use more than 2% bleach by volume with water. Let the sail soak with it and keep it wet. You could use a bathtub or a large clean plastic garbage can if you want to soak it overnight.
To wash your sail lay it out on a clean lawn and mix woolite and a scoop of Oxyclean. Don't use bleach if the sail looks good with little mildew. Scrub it with a soft bristle brush (car washing pole brush); rinse well and then allow it to dry in the sun. Just turn it every hour or so and it will dry out despite sitting on the lawn.
KeelHaulin is offline
