halyard @ top of mast
Don''t feel too badly about this. Been there, done that, got the Tee shirt. Unstepping a mast on a Catalina 22 should not be that hard. The mast is comparatively light and if I remember correctly they have a hinged mast step. Two people should be able to do it themselves. I had a 23 foot trimarran that I used to step and unstep the mast on it by myself. I would go to the Trailer Bulletin Board to see if there are any short cuts for stepping a Cat 22 mast. http://www.cruisecortez.com/webbbs/trailersailor/index.cgi
If you really do not want to lower your mast then the hot ticket is to tie up to a friend''s bigger boat (ideally 35 feet or more) and using your jib halyard around the other boats mast(ideally near his spreaders so you won''t damage their mast) haul your mast over until it is close to the big boat''s mast and then go up his mast and grab your halyard. This takes lots of fenders but probably is faster than dropping your mast. On the other hand if you lower your mast its a great chance to inspect it for wear and tear.
Good luck,
