SailNet Community - View Single Post - Tiny Dehumidifiers
post #9 of Old 06-01-2010
LazylighningII
EVA DRY Eva-Dry® Petite Electric Dehumidifier (EDV-1100)
AVAILABILITY: In stock, leaves warehouse in 1 - 7 full bus. days. - (details)
STORE AVAILABILITY: Your neighborhood Ace stocks thousands of products in the quantities you need. Check with your local Ace for availability. (find your local Ace)
Detachable tank that holds 16 oz. of water
Whisper Technology (no compressor) which makes it light and quiet
Small and easily portable- weighs less than 5 lbs.
Automatically shuts off when full
Great for closets, storage rooms, nurseries, bedrooms, and other locations where humidity is a problem
1 year manufacturers warranty from any manufacturer defects
UL and CE listed
Product dimensions: 8.5"H x 6"W x 4.5"D
Review Snapshot® by PowerReviews
Avg. Customer Rating: 3.8 stars
(based on 4 reviews)
75% of respondents would recommend this to a friend.
Customers most agreed on the following attributes:
Pros:Compact (3), Effective (3), Lightweight (3)
Primary use:Personal (4)Already own it? Write a Review
closeReviewed by 4 CustomersSort by:Newest firstOldest firstHighest ratings firstLowest ratings firstMost helpful firstLeast helpful firstDisplaying Reviews 1-4 of 4Back to Top
[2 of 2 customers found this review helpful]
nice little machine
By Brad from Des Moines, IA on 9/12/2009
Comments about EVA DRY Eva-Dry® Petite Electric Dehumidifier (EDV-1100):
I bought this dehumidifier for a basement room with carpet that is approximately 12x15 feet. It does a good job of keeping the room dry, even when the rest of the basement is not. It takes about two days to fill, and I find emptying to be very easy. The small size is nice because I can tuck it out of the way.
I wouldn't call it whisper quiet, but it's not bad. We also have a space heater/fan that we run during the winter, and this dehumidifier is quieter than that.
Pros:Compact, Effective, Lightweight
Best Usesank Basement, Summer Humidity
Bottom Line:Yes, I would recommend this to a friend
Was this review helpful to you? Yes / No- You may also flag this review.
Works Great!
By George from Portland, OR on 12/1/2008
Unit is just the right size for the forward cabin. Maintains humidity at about 45%. If your boat is over 25 feet or so a larger or second unit will probably be required.
Cons:Noisy for living space, Power light is bright
Best Uses:On a sailboat
Describe Yourself:Boat owner
[3 of 3 customers found this review helpful]
Small but useful
By Susan from Oakland, CA on 1/19/2008
This dehumidifer has been very useful and it's working great.
The water tank fills up quickly in my basement so I have to continue to
empty it out. Probably would be better for smaller spaces.
Best Uses:Bathroom, Dank Basement
Describe Yourself:Homeowner
[1 of 7 customers found this review helpful]
One word -- worthless
By Whitebird from SW FL on 12/25/2007
I was very disappointed. This sounded liked the perfect product for my closet. However, it proved to be absolutely useless and I returned it.
Pros:Quiet
Cons:Ineffective, Very ineffective.
Best Uses:Summer Humidity, Used in walk in closet.
Bottom Line:No, I would not recommend this to a friend
LazylighningII is offline
