SailNet Community - View Single Post - the head pump is harder to pump
post #3 of Old 06-03-2010
JiffyLube
Grasshopper
JiffyLube's Avatar
I rebuilt our Groco pump once. An O-ring goes around the piston of the pump in the chamber, and if it's hard to pump then I would lube up the chamber the piston is in. This will allow the O-ring to slide much easier. Lube with anything that will not affect the rubber of the O-ring.
JiffyLube is offline
