SailNet Community - View Single Post - the head pump is harder to pump
post #6 of Old 06-03-2010
Cruisingdad
Best Looking MALE Mod
Cruisingdad's Avatar
I have found teh best thing for the rod is Pool grease. It works well and lasts quite a while. If you have a Wilcox, you can try to loosen the black plastic nut on top, but will probably cause it to leak a little. It is also very likely that the rubber ring on the piston is getting hard/swollen. This is very common as they age - especially on the cheaper toilets. You can prolong its life by adding oil... we use mineral oil. I guess we use about an 1/8 cup initial, then a light coating every week or so and certainly with every pumpout.
If that does not work, you may be due a replace or rebuild. Be aware that on the cheaper toilets the costs to replace the whole assembly usually runs only a few dollars more (relatively) than the rebuild kit and is a WHOLE LOT EASIER and with less mess.
Just some thoughts. Good luck with it.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
