SailNet Community - View Single Post - jb weld
Thread: jb weld
post #7 of Old 06-03-2010
scottyt
if you can see the problem go find your local hvac guy, he has a torch and the silver to fix it on the boat. you would just need to drain the HX. even home depot sells brazing rod that will fix it, but the torch needs more heat than a propane or mapp will put out. you might get away with the oxy mapp setup that HD sells
scottyt is offline
