SailNet Community - View Single Post - Wiring Problems I Can Help!12v,or 110v
post #3 of Old 05-05-2006 Thread Starter
Do You Have An Inboard Motor Or Out Board ?if Its In Board Ground Directly To The Motor Block'and Back To Box; If Outboard Ground Boxes Together This YOU WILL need To Check For Condinuity From Box To Box First.if You Have A Good Resistance This Will Work;also Check If Your Inverter It Should Have A Indipendent Ground If So Use That,
TUNDAR4 is offline
