SailNet Community - View Single Post - what gauge wire to use with a Fourwinds 2 wind generator
post #1 of Old 06-06-2010 Thread Starter
Bene505
Glad I found Sailnet
Bene505's Avatar
Anyone have a FourwindsII installed? I need to know what gauge wiring to use for connecting the generator to the battery (directly connected) and what gauge wire to use from the battery - through a Xantrex c60 - and to a dump load.
For the second part, I already have 6 gauge wire run to the secondary switch panel that's only used for the washdown pump. I may make that a dedicated wire for the dump load. Why am I not sure about making it dedicated? Because if it's in use, it will already be dumping the load, so it will then be needed less. Anyway, that's what I'm thinking.
It's that first part that I'm wondering about. Just how much current can one expect to get out of a FourwindsII. The website has a chart with amperages listed for different wind speeds.
But the chart doesn't show the top end. The specs say 300 watts, but I'm not sure I believe it and want to make sure I'm not frying the wires -- which would then put the generator into no-load overspeed, somthing the air brake should help with.
So what wire gauge does your FourwindsII use to connect to your battery bank?
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
