On my A4 the orginal pump was so worn out i had to buy the Moyer Marine unit and replace it
You would need to inspect the pump and look at the shaft bore (my bore had worn huge) and the wear plate the impeller runs on to make suction
Also if the cover plate and rear of the pump wear the sides of the impeller rub is worn it will not work well
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
If a dirty bottom slows you down what do you think it does to your boat To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
