Great Boat Compare to other .
The best thing is that Author said that:
Unlike lockers that compromise living quarters, the one on this boat is on centerline under the cockpit sole. It offers room for a six-man liferaft and has built-in chocks to which an anchor may be secured. The engine/locker structure is part of the hull structure, which eliminates flexing of the sole. Hull No. 1 was fitted with a bladder tank that has since been replaced by a fiberglass tank located to starboard of the engine. The tank, which can be easily removed for filling on a dock, is attached to a pump.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
