SailNet Community - View Single Post - Wiring Problems I Can Help!12v,or 110v
post #4 of Old 05-09-2006
An important check while you are at is to make sure that you have NO connection between green wire ground and AC common on your boat.
The green wire ground should connect to your DC ground block.
DeepFrz is offline
