SailNet Community - View Single Post - Check my math
Thread: Check my math
post #2 of Old 06-13-2010
sailingdog
That's when you start motoring... The real problem is if you have blown out sails, your ability to go to windward is going to really be limited.
Sailing in areas with strong currents really require you to use some forethought and planning in timing your passages. For instance, a boat that can only do 5 knots really will get hammered if there is a 3 knot current. If the current is against you, you end up going at 40% of your boat's real speed... but if you have the same current with you, you end up going 160% of your boat's real speed, and end up making the voyage in ONE-FOURTH the time...
sailingdog is offline
