Some are fixed fin keel and some centerboard. the CB's are a bit tender. We ordered new sails and scaled the jib down to a 120. The boat is easily driven, so even a 110 would do. The fixed keel is less tender. Both sail high and fast. Bristol continued to build the "old" style and started this "new design' at the same time. You can figure out which design won out. They are, IMO and having sailed both, a better design. We were specifically looking for a centerboard to allow us to get into the skinny water. Prior to this we had the 31.1 with fixed fin keel. That is a sweet boat as well, and adequate room for a couple. You can find one in very good shape for aroung 60K. We moved up to the 35.5 to gain waterline and additional storage. After that you go to the 38.8, but I would look at the Wasquiez if you are wiling to go to or beyond the 100K mark.
Larry
