SailNet Community - View Single Post - New Windlass twisting line / chain - change 3-strand or add anchor swivel?
post #2 of Old 06-16-2010
lancelot9898
I also have a similar setup with the anchor rode as you including the Manson Supreme which I like very much. I'm using 80 ft of BBB chain spliced to 3 strand and do have some twist induced whenever I use a lot of rode. However most of the time I'm anchored in shallow waters and not much 3 strand in used. 8 plait will solve the problem, but I would stay away from swivels even though the manufactures claims they do not induce a weak link. A couple of years ago when replacing the rode, I went with 3 strand over the 8 plait because of the preceived chafe resistance of the 3 strand over the plait. Not sure how significant that is and if that benefit outweighs the twist problem. Also there is more stretch with the 3 strand over the plait and that could either be a plus or minus depending how you evaluate it.
lancelot9898 is offline
