SailNet Community - View Single Post - How to Point Better
post #6 of Old 06-28-2010
DrB
Backwindfrom a 155-160
Originally Posted by Sailormon6 View Post
The short answer is - maximize your speed. Increasing boat speed increases pointing ability. Never pinch. Although it sounds contradictory, the general principle is that you should bear off to point. The old timers used to say you should "give her a snoot full of wind." As boat speed increases, the apparent wind increases, and the lift that is generated by the sails increases, and the lift that is generated by the keel increases. In every respect, the boat becomes more powerful. After the boat has accelerated to her maximum speed for the conditions, then ease the pressure on the tiller slightly, and let her continue driving to windward at her maximum speed, with her best pointing ability.
Pinching is deadly, because it reduces boat speed, which reduces apparent wind, which reduces all the forces exerted above and below the waterline.
Also, it sounds like you had the genoa sheeted in much too tight. I can't think of any conditions in which I have ever benefited by having a 155-160% genoa sheeted to within a couple of inches of the spreaders. They need a slightly fuller shape to generate maximum power. Also, they're likely to backwind the mainsail when sheeted that close.
Is it even possible to fly a 155-160 and NOT get a back winded main when closehauled or near closehauled? If the main is back winded, it is not 100% efficient, which may be why the OP is not getting the best speed. For a race, the max I would fly is a 150% and then only in the lightest of air (8 kts or less).
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
