Old 05-19-2006
msammons msammons is offline
msammons is on a distinguished road
Low RPM
Your throttle cabel may be sticking int he housing. Take off the binnacle compass loosen th throttle cable and spray Dry Lube down it. Work the cable back and forth to spread the lube and tha shuld loosen it up. Tha alwys fixed my C30. DO NOt use WD40. you may have to ultimadely replace the cable.
Mike
