SailNet Community - View Single Post - I love to learn the hard way!!!
post #3 of Old 07-01-2010
erps
the pointy end is the bow
erps's Avatar
I find I remember the lessons a lot better when I learn them the hard way. I kept previous boats on a mooring for about 15 years. I had our boat on the beach a couple of times and learned a new weak spot with the way I designed our mooring each time.
Lesson #1: I had a large nylon mooring line that went all the way down to a bouncer block with a float about six feet up to keep the line from wrapping up and chafing. In a blow, the bouncer block got tipped over. Now my mooring line is upside down and quickly chaffed through. So I added a length of chain later on.
Lesson #2. Don't mix stainless safety wire with galvanized fittings. The stainless wire caused the galvanized fittings to wear out prematurely because of galvanic action. Found boat on the beach again and then switched to plastic wire ties on all the underwater fittings.
Lots of other mistakes learned the hard way, but I must try and maintain the little bit of dignity I have left.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
