SailNet Community - View Single Post - Replacing bulkhead bolted chainplates with deck bolted with a wire strut
post #2 of Old 07-02-2010
sailingdog
While most machine shops could make them for you, I wouldn't recommend doing that without consulting a marine architect. Your boat was designed to have its rig in a certain position and moving it may cause serious issues.
I'd point out that the bulkhead in question is clearly structural, and needs to be replaced before you can use the boat.
It would help if you said what kind of boat you had, since there may be a known fix for the boat that other owners have come up with.
sailingdog is offline
