SailNet Community - View Single Post - Replacing bulkhead bolted chainplates with deck bolted with a wire strut
post #3 of Old 07-02-2010
mitiempo
mitiempo's Avatar
I agree with dog. While the chainplate in pics 3 & 4 looks good, the original method used on your boat is probably stronger with a solid bulkhead properly glassed in as it spreads the load over a wider area. Most manufacturers use a method like this because of its strength. Usually they only vary it when the accomodations don't allow it.
As dog said the bulkhead requires proper replacement regardless.
Brian
mitiempo is offline
