SailNet Community - View Single Post - Replacing bulkhead bolted chainplates with deck bolted with a wire strut
post #7 of Old 07-02-2010
mitiempo
mitiempo's Avatar
Manufacturers seldom use an off the shelf chainplate, most are custom for each model. You might be able to find one similar but probably not exactly what you want. The hole has to be the correct size for the toggle or turnbuckle your rig uses. A hole too large is a problem. What boat do you have? Maybe someone here could help more if we knew.
Brian
mitiempo is offline
