Old 07-04-2010
MAnDaRIn MAnDaRIn is offline
MAnDaRIn is on a distinguished road
Originally Posted by mitiempo View Post
The compression post is sitting on the cabin sole. I guess there is a structure under the sole that goes to the bottom of the hull on top of the keel. How would you transfer the upwards load of the chainplates to that?
I think the best way to do that is to use the bulkhead. I would replace the beam on the side of the bulkhead opposite the compression post and more or less duplicate the original design. Or I would move them outboard a few inches and use the hull itself. Bolt the chainplates through the hull afer first beefing up the area by glassing, with epoxy and biaxial cloth, a thick pad on the hull inside to spread the load. The pad should probably extend about 18" down from the hull/deck join and a ways fore and aft. This will transfer the loads to a much wider area.
whats a good way to repair the bulkhead without replacing the entire piece of ply. Someone took the chainplate out of the original holes and moved it over a inch and bolted it again, I want it in its original spot. I don't see or feel any rot when i prod it with a screw driver in the original holes and its not laminating. I'm going to sand it down and I was thinking I could epoxy both sets of holes and build up a epoxy pad where the chainplate would go.
