SailNet Community - View Single Post - Replacing bulkhead bolted chainplates with deck bolted with a wire strut
post #26 of Old 07-04-2010
mitiempo
mitiempo's Avatar
That should work. You could also add a doubler on the other side of the bulkhead, epoxied to the bulkhead for added strength. It will have to be on the other side as if in the main cabin it would cause the chainplate to be moved aft by its thickness.
Brian
mitiempo is online now
