SailNet Community - View Single Post - Teak trim plugs and varnish
post #2 of Old 05-22-2006
TUNDAR4
Cut Plugs
Cut Or Sand Your Plugs 1/16" Less Than The Hole Depth ,after You Apply Your Finish Sand Edges Of Plugs And Holes ,so It Wont Chip Finish,then After You Get The Trim Back In ,apply A Little Glue ,put Plug In. I Use A Padded Block Of Wood Laying Flat On Trim Tap Wood Block Lightly With Hammer.untill Flush,
TUNDAR4 is offline
