Old 07-07-2010
blt2ski's Avatar
blt2ski blt2ski is offline
Yes it is a "Sabb"
The pitch part is not to bad to work with, the rpm lever tho. PITA! move it 2-3 degree's, and the motor goes from 700-1200 or higher rpm!
I have gone out with step sister a few times, think we have it down, or at least a "HOW" to back out etc. Seems to work best if the motor is 800-1000 rpm, slowly engage the blades in reverse, then as she is 90 to the dock or just a bit before to move blades into the forward and away one goes out of the marina, with some upping of rpm or just engaging the prop into a higher pitch mode.
This boat, maybe being a V bottom plywood full keel, about 5500 lbs does not coast real well, not does it turn super sharp, as one can not get the rudder/tiller to go as far as one would like, which also makes backing out a pita along with trying to get the motor/prop etc in a correct mode so it will idle out per say.
Marty
She drives me boat,
I drives me dinghy!
