SailNet Community - View Single Post - For sale: 1998 Island Packet 37
Old 07-07-2010
Volkhard's Avatar
Volkhard Volkhard is offline
Volkhard is on a distinguished road
Basic boat description Island Packet 37
Hull # 053
Classification Category A Ocean
LOA 38'5" or 11.70 meter
LOD 36'5" or 11.10 meter
LWL 31'.0" or 9.45 meter
Beam 12'2" or 3.70 meter
Draft 4'6" or 1.37 meter
Mast above DWL 49'6" or 15.10 meter
Fuel capacity 50 gal(US) or 189 liter
Water capacity 90 gal(US) or 341 liter
Holding tank 12 gal(US) or 46 liter
Headroom 6'4" or 1.93 meter
Displacement (approx) 18,500 lbs or 8,409 kg
Ballast 8,200 lbs or 3,727 kg
Sail Area 800sqft or 74.3 m2
Main 284sqft, full battened
Genoa 384 sqft on roller furling
Staysail 132sqft, self tending, rollerfurling hoist boom
Ratios
Sail Area / Displacement 18.3
Displacement / Length 277
Ballast / Displacement 44%
Engine 38hp Yanmar 3JH2E
Engine hours (approx) 2350 (May 2010)
Transmission KBW 10E
Cabins / Berth 3 / 7
Head / Shower 1 / 1
Construction
Solid (no core) Fiberglass construction with Triaxial roving for the hull.
Cored Fiberglass construction with Poly Core for the deck, cabintop & cockpit.
Integrated laminated Fiberglass construction for the bowsprit.
ISO/ORTHO/NPG premium gelcoat.
Poly Clad barrier gel system to prevent osmotic blisters below waterline.
Chemical bond (3M 5200) + SS Bolts (6" spacing) + massive Teak Caprail for Hull/Deck joint.
1/2" backing plates for deck hardware
Edson rack & pinion steering for superior strength and feel
Keel stepped mast
Factory installed systems (included in original base price):
isolated icebox, with light and icebox drain pump.
LPG locker for 2 tanks (10lbs each) with safety solenoid
3 burner stove with oven (LPG) (gimbaled), Model Seaward
Fresh water pressured system with PAR diaphragm pump.
Hot/cold faucets in galley and head
hot/cold shower
cold shower in cockpit
Dockside pressured (city) water input in cockpit
Blakes LaVac manual vacuum head with manual diaphragm pump( 2008 - as replacement for original Raritan PHII manual head)
Dometic/Sealand HTS holding Tank (2009 as replacement for original aluminum holding tank.
Whale MK 5 manual diaphragm discharge pump for holding tank discharge (2008 as replacment for original Jabsco electric mascerator pump)
3 way valves (2x) retrofitted for direct head discharge & holding tank discharge
all sanitation hoses replaced with Trident odor safe during retrofit (2008)
head raised by 2.25" with starboard raiser during retrofit (2008)
Atwood waterheater EHM6 (6 gal) operated by engine heat and 110V shorepower.
Monitor for fuel tank at nav station.
Monitor for fresh water tank at nav station.
Ample ventilation through multitude of hatches and portholes.
Florida Sailor
ODYSSEY
Island Packet 37 (hull53)
