SailNet Community - View Single Post - Maxsea and USB GPS troubles
post #3 of Old 07-08-2010
sailingdog
Have you tried reading the GPS in a terminal program?
According to the manual, it should be outputting the following:
NMEA V3.0 Protocol
Its output signal level is TTL: 4800 bps (default), 8 bit data, 1 stop bit and no parity. It supports
the following NMEA-0183
Messages: GGA, GLL, GSA, GSV, RMC and VTG.
Log the data coming from the GPS in your terminal program and look for the GLL message. The data string that you should be looking for would look like this:
$GPGLL, 3723.2475, N, 12158.3416, W, 161229.487, A*2C
If you're not seeing that line in the data capture from the GPS with valid lat/long data, then the GPS may be defective.
If you see the data okay in the terminal program, then there may be an issue with the serial port you have it set as. Try changing which serial port it shows up as. This is probably something you can change/set in the driver.
sailingdog is offline
