Old 07-16-2010
alex909 alex909 is offline
alex909 is on a distinguished road
How to install hardware on cabin top when I can't access the underside?
I have a Beneteau 343 and would like to install a cam cleat on a 1" riser on each side of the cabin top to run my traveler lines through (currently, they go through rope clutches).
I need to mount them in a place that has no access underneath for me to screw on the bolt or add a backing plate. Is there a way to do this securely so that it can handle the loads? Do I fill the space under the screws with epoxy or some other kind of filler and then screw them on without bolts or backing? There is an access plate under the winch and judging by that, there is probably a 1" gap between the cabin top and the liner beneath where I want to put my cleats.
Pardon the ignorance, I've never had to drill a hole on my boat and I want to make sure I get it right. Please let me know if I haven't been clear in explaining my question. I tried to upload some photos of the location but the uploads kept failing. I can send pics on request privately if it'll help.
Thanks for the help!
Alex
