SailNet Community - View Single Post - Hull Construction
post #1 of Old 05-25-2006 Thread Starter
Bernie K
Hull Construction
In search of the perfect boat...I've read pros and cons of various hulls but am confused when I see a hull advertised as "vacuum bagged, oven cured epoxy hull, variable draft, high lift low cg bulbed lead keel". The confusing part is the "vacuum bagged, oven cured epoxy hull" -- what is this? Is it a core that over time could possibly absorb water if the vacuum bags crack/rip?
The same goes for the deck "vacuum bagged, infused vinylester composite" -- is this also a water absorbant material that has been bagged?
Any inputs would be appreciated.
Bernie
Bernie K is offline
