SailNet Community - View Single Post - help! Rough running engine
post #3 of Old 07-17-2010
tommays
tommays's Avatar
As and inboard the sail-drive should not have and outboard motor like hand pump bulb installed below deck IF that is the primer you are describing ?
All the below deck fuel line should be A-1 type and the tank fill line and vent should be A-2
Its pretty common for well meaning previous owners to do things like this rather than fix the real problem with the fuel system
you have to be a bit careful as the OMC is a lot LIKE like the outboard it came from BUT the fuel/electric system was changed for a below deck install
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
