SailNet Community - View Single Post - Can't start My Yanmar
post #4 of Old 05-26-2006
Gene T
Gene T's Avatar
Always start at the source with fuel problems. Crud in the tank can easily plug the pick up tube, then air gets in the system past an o-ring at the filter. A vacuum gauge is one of the most useful instruments on a boat. A simple outboard bulb pump can be used from the tank to the filter to bleed the system, if the bulb collapses when the engine is running it means the pick up tube is plugged. Clean the tank, change filters.
Gene T is offline
