SailNet Community - View Single Post - Hairline crack on mast
post #4 of Old 07-26-2010
cormeum
48' wood S&S yawl
cormeum's Avatar
looks like someone tried drilling the mast to arrest the cracking already. you need to pull the insert whcih is probably where your problems lie. when that's addressed, welding a band on the base probably would only cost a couple of hundred- if the crack progresses the price to fix it mounts.
Capt. Force's solution is a good one too (if there isnt too much taper to refit the step)
"Never attribute to malice that which can be adequately explained by stupidity." - Robert A.Heinlein
cormeum is offline
