Thread: Coronado 41
Old 07-27-2010
svthefilthywhore svthefilthywhore is offline
skipper
svthefilthywhore is on a distinguished road
I have had a coronado 41 since 2006 and some things are true in my case. while we have found issues such as keel to hull joint issues and a couple of soft spots in the deck, both were maintenance issues that were ignored by the previous owner.
if the previous owner had re-bed the deck hardware in anything but silicone the stanchion bases wouldn't have leaked and got the core wet with fresh water. and if the PO had not let fresh water flood the bilge for about a decade I wouldn't have keel bolt issues. both of the issues I knew about when I purchased the vessel and were obvious.
you may ask "if you knew about those problems, why did you buy it?" because it was a good boat that needed a little bit of work, and she was a good buy for the money.
the truth is that coronado 41s are heavily built vessels that are not considered blue water boats only for the lack of sufficient water and fuel tanks. mine came from the factory with 40g water and 35g fuel. this makes her a coastal cruiser until I replace the original tanks with larger ones which take up all of the wasted space that went unused.
I find the cor-41 to be sea kindly while sailing, but when there is no wind she acts like any other boat with a 50% ballast to displacement ratio, this makes her recover from rolling too quickly, but this makes her more stable while sailing. with canvas up she barely feels chop on the beam and rarely reaches 20 degrees heel. under power with the original perkins 4-108, she moves along at about 6.5-7kts while burning about 1 gal per hour, but if you slow things down a bit to 5-5.5 kts she sips along at about 1/2 gal per hour. under sail she moves along efficiently for a vessel of her tonnage, needing only 10kts of wind to achieve her hull speed on a beam reach. while some may think that she has more windage from her flush deck, the truth is that she has little more windage above the waterline than other designs, the diference is that the height of the cabin is the entire width of the boat, not just in the middle. the rig is well designed with a short stout keel stepped mast supported with over-sized mast-head standing rigging. the shroud chainplates are through-deck type bolted to heavy all glass structural members, and fore and back stays through-bolted to the stem and stern.
while this boat has hull stiffening members, there are very little full height bulkheads, as is seen in modern cruisers. this allows some flexibility in the hull, while maximizing open space.
while turning this vessel into a world cruiser we will need to make several changes; tanks, upgrade steering to hydraulic, install an autopilot alternate power(solar panels) and more. this is comon to find more work than you think in a boat of this age, but as long as you use her you will get the money out of her.
I am happy with my coronado 41 and you will be too
