SailNet Community - View Single Post - Clutch slip?
Thread: Clutch slip?
post #3 of Old 07-27-2010 Thread Starter
Boondoggle30
Aura Columbia 30
Understand?.
Knots,
So if I understand you correctly, you suggest disconnect at helm end and move shifter to see if it binds? I replaced the "barrel connector" at the engine where the cable connects to the engine - that $100 part made very little difference. I think I will do what you say and while I have it off I may replace the cable. Is there any merit to tightening the cable (ie: shortening it) to tighten up the system?
I am assuming the linkage you are referring is the cable that runs from shift to engine correct?
Thanks. My concern in burning out my transmission as it is always slightly engaged??
Boondoggle30 is offline
