SailNet Community - View Single Post - Can't start My Yanmar
post #5 of Old 05-29-2006
camaraderie
moderate?
camaraderie's Avatar
from your note it sounds like you bled to the filter but not the hi pressure fuel pump (which lies between the engine mouted filter and the injectors). If you don't bleed the pump then the fuel can't get to the individual injectors. All the other advice above is great but if you did not bleed the pump as well I would try that first.
camaraderie is offline
