Ugh.
Is the hull cored below the waterline, or just the topsides? If cored below the waterline, did the leave solid laminate in place for the through hulls? If not solid laminate in the area of the through hulls, did they at least seal the core in those areas with epoxy?
It would probably be wise to say what kind of boat it is... as many boats have known problem areas that you need to watch out for. Say it is an 18 year old, 50' boat is pretty generic....
