SailNet Community - View Single Post - Cored deck soft spot repair
post #7 of Old 08-05-2010 Thread Starter
in over my head
Awesome info....Ill look into the chopped glass and resin. Im sure my core is wet, before I do the repair, I need to fix a lot of improperly installed hardware on the deck thats been leaking. (Im almost positive its the chainplates leaking most of the water.) Anyone ever used CPES? Ive been reading about it and it seems like it works really well if the deck is dried completely. Also, Im planning to hollow out and make an epoxy bed around my chainplates so this doesn't happen again.
how big were the soft spots you fixed? I have a pretty large but narrow area, approx. 5 ft. x 1 ft. along the portlights where the port stays are bolted into the deck.
Im looking seriously into CPES but Im thinking it would be better, and not much more work or expense just to recore.....I just dont like the idea of cutting up my deck when Ive never worked with fiberglass before.
Thoughts anyone?
1976 Catalina 27
St. Pete, FL
sync is offline
