SailNet Community - View Single Post - Oil in Heat Exchanger
post #33 of Old 08-05-2010
hellosailor
If you can get that hole welded up, you're back in business. Polish off the rust, check the block and head for warping while you are at it, do a leakdown test on the cylinders to make sure the rings and walls are still OK. (Piston down, fill cylinder with kero or diesel, see if it leaks down past the rings overnight. And of course--drain and change the oil afterwards if it does.)
The engine looks OK from here but that's a view from a distance. :-)
hellosailor is offline
