SailNet Community - View Single Post - Surveyor in LA, Long Beach, Newport area ? Any recco's
Old 06-01-2006
sailingdog sailingdog is offline
I'd also recommend that you hire your own surveyor, not use one recommended by the seller or broker.
Is the boat USCG documented? Documented boats are easier to trace the history of.
Certain brands have a history of problems with the cores getting wet, especially in the case of teak decked boats. The cause in the case of teak-decked boats is usually the screws letting water enter the core.
What material is the core? End-grain balsa is pretty resilient to rot and doesn't really allow moisture to migrate. Marine plywood fares worse than balsa generally. The PVC-based foams will allow moisture to migrate but won't rot. There are a few other core materials, but the ones I've mentioned are the most common.
