SailNet Community - View Single Post - Help! Volvo Penta Md5b?!?!?!?!
post #2 of Old 08-07-2010
Gene T
Gene T's Avatar
What do you mean you cleaned the injector? That is pretty much a job for a diesel shop. They test it to see the spray pattern and rebuild as needed.
You can bypass your fuel tank and just run your fuel hose into a jug with clean diesel.
Exhaust could be plugged. Does water pump out of the exhaust while you are spinning it over? Then probably ok.
Keep at it. I suspect you will get it figured out.
Gene
Currently in Long Beach, CA
Gene T is offline
