SailNet Community - View Single Post - Installing a Cleat... Need Help
post #6 of Old 08-08-2010
sailingdog
Why not use something like a toggle bolt to fasten the cleat. It isn't ideal, but it is a hell of a lot better than relying on screws in relatively brittle fiberglass. I'm thinking of something like this:
Which would be relatively easy to install, and if you wanted more security with it, you could always inject thickened epoxy around it to secure it to the hull and prevent any water intrusion.
It is essentially retrofitting a tapped metal plate into the hull as JRP mentioned builders sometimes do.
sailingdog is offline
