SailNet Community - View Single Post - How does engine shutoff work?
post #7 of Old 08-09-2010
sailingdog
Good points both...and as I said, cutting off the air intake is an emergency measure....
Originally Posted by Gene T View Post
Yes but it is now important to mention. DO NOT USE YOUR HAND TO STOP AIR FLOW TO THE ENGINE! Doing so could result in a loss of part of your hand as this is a very powerful suction.
Should also point out that an engine can keep running with the fuel shut off under fault certain conditions. It will run on the engine crankcase oil around the rings if someone put too much oil in the crankcase or in some cases if the engine gets super over heated. In which case the only way to stop it is to plug the intake.
Gene
sailingdog is offline
