SailNet Community - View Single Post - GPS and Compass show different headings
post #2 of Old 08-10-2010
sailingdog
In many areas, there are ranges setup for things like navigating channels. You can use one of these to check the magnetic compass heading, since the range is a known bearing line. Granted, you may have to correct any deviation in the compass by swinging it, but checking it against the range will tell you whether you're in the ballpark or not.
If there aren't any ranges convenient to you, you can always setup your own ranges using things like radio, water towers, etc., to create a known bearing.
sailingdog is offline
