SailNet Community - View Single Post - stuck keel
Thread: stuck keel
post #6 of Old 08-11-2010
Boasun
Boasun's Avatar
The bleach kills the barnacles but really don't remove them...
Remove the top cap of your center board well and using a steel yard stick or a flat piece of steel and slide it down between the center board and the well. This will help remove anything that shouldn't be there.
Also check the pivot pin and the babbit bearing that your CB swings on. It could be flat on the top and creating fiction in lowering it.
Also check the CB itself. If a low grade of steel it could have swollen with rust and causing problems from that.
Check your well box and see if the wood(?) is swollen from a lack of paint maintenance care.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
