SailNet Community - View Single Post - Help with packing problem
post #6 of Old 08-12-2010
sailingdog
I'd point out that if you're using a traditional stuffing box, regardless of the packing material, and it isn't DRIPPING...then you've overtightened more likely than not and are probably scoring the shaft. A traditional stuffing box NEEDS WATER as a lubricant, and if it isn't dripping at least a little bit, especially when the shaft is turning—it is probably running DRY. Even the GFO Goretex packing material REQUIRES SOME WATER PASSING THROUGH IT.
sailingdog is offline
